Calculation question related to a tables with a one-to-many relationship
  • Sep 28, 2026 8:21 PM UTC
  • 60 views
datablue
Forum|alt.badge.img+11
I’m trying to figure out how to add new attribute and calculate a specific value.
I have a Survey123 survey that submits records to ArcGIS Online. Each survey contains one location, and one or more inspections (this is an example). In ArcGIS, this is stored in two tables with a one-to-many relationship. Each location has a field with a unique ID and each inspection has a field with the inspection number literally 1, 2, 3, and so on. Records in the two tables look like this.
Locations table
Location A.
Location B.
Location C.
Location D.
Inspections table
A. Inspection 1.
B. Inspection 1.
B. Inspection 2.
C. Inspection 1.
C. Inspection 2.
C. Inspection 3.
D. Inspection 1.
In FME Form, I join the tables so the records look like this.
Location A. Inspection 1.
Location B. Inspection 1.
Location B. Inspection 2.
Location C. Inspection 1.
Location C. Inspection 2.
Location C. Inspection 3.
Location D. Inspection 1.
I’m trying to figure out how to add a “number of inspections” field to each record like this.
Number of inspections for Location A: 1
Number of inspections for Location B: 2
Number of inspections for Location C: 3
Number of inspections for Location D: 1
As far as I can tell, this is either not easy or impossible. It occurs to me that I may be able to modify my survey and add the Number of Inspections field there. This might be the easiest solution.
Does anyone have thoughts on this?
Thank you,
Chuck
Best answer by geomancer
Have you looked at the StatisticsCalculator?
In this transformer you can determine the total count for each location, and add this attribute to every record.
Then use the results from the Complete port.
geomancer
Forum|alt.badge.img+71
  • Sep 29, 2026 5:45 AM UTC
datablue
  • Sep 29, 2026 10:01 PM UTC
Thanks for a great solution! I was really stumped on this. I’ve used the StatisticsCalculator before, but I had never used the Complete port. The default connection is the Summary port. Now, that I know how to use the StatisticsCalculator with the Complete port I can see me using this transformer more often.
I also needed to show the Location Count to display the number of locations for the currently selected inspectors (people) in my ArcGIS Dashboard. To do this I added a LocationCount integer (not the best name) then set it to 1 when Inspection# == 1, otherwise I set it to 0. In the dashboard, I sum the LocationCount for the current records and that works great.
