Calculate slope along lines
  • Nov 23, 2017 3:02 PM UTC
  • 9 replies
  • 518 views
ireen
Forum|alt.badge.img+5
Hello,
I want to make a FME model in which the slope along bicycle routes is determined, as well as the direction of the slope (uphill/downhill).
My idea:
- dividing the network in small parts of +/- 50 metres long (LineDivider)
- define the elevation of the start- and endpoint of the lines, as well as the direction
- calculate the slope in between these points + direction
Anyone who can help me with this?
jdh
Forum|alt.badge.img+41
  • Nov 23, 2017 9:36 PM UTC
What about getting a DEM and running it through a RasterSlopeCalculator and a RasterAspectCalculator, then breaking your lines into points (presumably densified first) and using a PointOnRasterValueExtractor.
ireen
  • Nov 24, 2017 7:40 AM UTC
The issue is that the result should be presented on a cycling map, showing the slope and slope direction on the route segments. When I break the lines into points and get values by the PointOnRasterValueExtractor, I will get punctual information that's possibly not representative for the whole route section.
  • Nov 24, 2017 9:23 AM UTC
Hi @ireen, if you have a surface model (DEM raster, point cloud, set of 3D points etc.) covering the area, you can drape the lines with the SurfaceDraper (Drape Method: VERTEX). You can then calculate the slope of a line from z-coordinates of start/end nodes and length.
Forum|alt.badge.img+63
That's what I did for a cycling map.
((@Value(_zmax)-@Value(_zmin))/@Value(_length))*100
Gives you a slope percentage (10m of rise over 100m horizontal is a 10% slope). This was not for a route, so instead of _zmax and _zmin (from a BoundsExtractor) use the first and last z-values, a negative slope means you're going downhill (whee!)
ireen
  • Dec 14, 2017 3:15 PM UTC
Hi Takashi, I'm still struggling with the surface draper. I get an error saying that Rasters with multiple bands are unsupported, but my reader contains a raster with only 1 band. Nevertheless, I tried the Raster band separator transformer, but this results in the same raster and the same error ("SurfaceDraper(SurfaceModelFactory): Rasters with multiple bands are unsupported."). Any idea what I'm doing wrong?
  • Dec 15, 2017 2:59 AM UTC
The SurfaceDraper should not raise the error "Rasters with multiple bands are unsupported" if the input raster has just a single band without palette, but it raise another error "Palettes are not supported by this factory" if the single band raster has a palette.
Firstly send the raster to an Inspector to check the data structure with Feature Information window in FME Data Inspector.
Example 1: DEM Raster (Single Band Numeric Raster)
Example 2: RGB Color Image (Three Bands Image Raster)
ireen
  • Dec 18, 2017 8:07 AM UTC
Hi Takashi,
The inspector indeed shows there are 2 bands ... The rasterbandsplitter does not result in 2 rasters, but also 1 (the same). Is there another way to remove the ALPHA8-band?
Thanks a lot for your help!
  • Dec 18, 2017 8:23 AM UTC
The RasterBandSeparator should separate a raster with multiple bands into multiple rasters with single band. I think it's a case that should be investigated by Safe support.
As a workaround in the interim, the RasterSelector and the RasterBandRemover (or Keeper) should work as well. Try this.
ireen
  • Dec 18, 2017 8:35 AM UTC
OK, I'll try it this way.
