Calculate percentage coverage from raster cell values
  • Apr 5, 2018 11:05 AM UTC
  • 207 views
djmcdermott
Forum|alt.badge.img+7
Good day FME'ers
I am trying to calculate the percentage green/grey from an single band NDVI raster image, i.e. the percentage of the raster that have cell values >= and < -0.1.
Can anybody help?
Thanks,
David McDermott
Best answer by jdh
Without dropping into python, I would suggest PointCloudCombiner to turn your raster into a point cloud, PointCloudSplitter (using the range you identify as green/grey) and then a PointCloudPropertyExtractor (don't extract any of the components) to get the number of points as an attribute.
Alternatively you could use the PointCloudFilter instead of the Splitter.
gavinpark
Forum|alt.badge.img+12
  • Apr 5, 2018 11:18 AM UTC
Are you trying to break the data down into areas like property boundaries or classify the whole image?
You should be able to use the RasterCellValueReplacer transformer to assign a lookup value for green and grey. Depending on how you are then looking at the output you should be able to calculate the amount of green/grey. Depending on if your looking at a region or the image level there are then a couple of different ways to look at the stats, but treating the raster as a PointCloud can be more performant.
djmcdermott
  • Apr 5, 2018 12:56 PM UTC
Hi @gavinpark3
I am starting by trying the classify a single tile to determine the green/grey percentage split withing the extent of the raster. I have read that treating the data as a point cloud could be better. The eventual aim is to assigned the % green/grey (or vegetation/other) to LSOA or Ward boundaries. Then a user can click on the polygon on the map and it'll provide info on how green an area is (like the Sterling Geo Smart Mapp). I hope that offers a bit more context.
jdh
Forum|alt.badge.img+41
  • Apr 5, 2018 1:53 PM UTC
djmcdermott
  • Apr 13, 2018 1:55 PM UTC
Hi @jdh,
Thank you for your response. Using your advice I managed to cobble something together that does the trick. I have attached it to this comment for you and others to use/refine.
greengrey.fmw
Thanks
