Calculate new measures as a result of a LineOnAreaOverlay
  • Feb 22, 2018 1:26 PM UTC
  • 30 views
pschout
Forum|alt.badge.img+7
Hi all,
I have the next question : is it possible to make a LineOnAreaOverlay and calculate new measures (based on the origin measures) of the output lines that intersect the polygons? The origin lines are roadsections and have a start and end measure (hectopoints).
See also the attached png:
yes, you can use measureExtractor (by vertices index : 0 for the line start and -1 for the line end)
