CAD TO GIS TRANSFORMATION
  • Apr 13, 2013 1:17 AM UTC
  • 120 views
HI EVERYBODY,
I HAVE SOME PROBLEM ABOUT THE PROCESS TO TRANSFORM CAD FILES CONSIST OF DWG AND DXF FILE TO GIS..IS THERE HAVE ANY SOLUTION ON HOW TO GET SIMILAR CHARACTERISTICS AT LAYER NAME, COLOR, ATTRIBUTE AND TEXT (ANNOTATION) WHEN WE CONVERT FROM CAD TO GIS?IS ANYBODY KNOW HOW USING FME TO SOLVE THE PROBLEM?IF CAN PLEASE SHOW ME A DETAILS..THANKS...=)
Best answer by geographygeek
There is an FME template for CAD to GIS transformation. That should help you to start. If you need more details, contact me, I can help you with CAD to GIS workflow.
geographygeek
  • Apr 13, 2013 2:59 PM UTC
  • Apr 13, 2013 7:17 PM UTC
that is a very general question with no single answer, but you could start with this recorded webinar video from Safe on the topic. It might clarify how FME works and what it can do for you.
David
  • Apr 14, 2013 3:54 AM UTC
I find the easiest way to go from CAD to GIS is to open the CAD file in the Universal Viewer and Save the data as...
Making sure you choose Layer Name in the parameters dialog when opening into the Viewer.
  • Aug 2, 2013 6:57 PM UTC
This writing is for geographyge ek. I see you listed above a template for CAD to GIS transformation, but I can't find it anywhere. Can you give me the location of where it's located? Thank you for you time and help!
