Bulk copy failed on table 'mytablet' using delimiter. Error was 'ERROR: Geometry type (CompoundCurve) does not match column type (LineString)
  • May 3, 2023 7:57 PM UTC
  • 260 views
I have tried using the combination of this transformers to discard or filter out compoundCurve geometry but the issue still persist
I would like to find a way to discard these geometry ("CompoundCurve".) to avoid the WB stops when I am inserting data to postgis table.
GeometryFilter
GeometryValidator
ArcStrokcer
GeometryRefiner
caracadrian
Forum|alt.badge.img+23
  • May 4, 2023 11:14 AM UTC
CompoundCurve is a tipe of aggregate.
Use Deaggregator (flatten one level or all levels, whichever suites you better) followed by GeometryRefiner and, if necessary, ArcStroker, in this order.
  • May 4, 2023 5:40 PM UTC
@caracadrian​
I have used Deaggregator  one level and all level and the issues persist , this is the combination used
GeometryFilter
GeometryValidator
ArcStrokcer
GeometryRefiner
Deaggregator
caracadrian
  • May 4, 2023 6:01 PM UTC
Can you post some sample data?
This usually is tricky but has a stupid easy solution. The order of the transformers matters (GeometryRefiner then Deaggregator or viceversa), the validity of the geometry also is particularly important, but it's always a different solution.
Also, keep in mind we are in opposite time zones. It's almost bedtime in Bucharest😁
