Bulk attribute rename problem
  • October 21, 2016
  • 6 replies
  • 135 views
Hello, in FME 2015 I have used @takashi solution to creating attribute names from one column value and populate those attributes with values from another column (http://fme-memorandum-takashi.blogspot.cz/2013/07/bulkattributerenamer.html)
Basically if I use the bulkattributerenamer this way in FME 2016 NOTHING changes, output data look the same as input data, while in FME 2015 it does work, as shown in the images bellow.
However this seems to not work in FME 2016.0 and above - I have tested it in 2016.0 and 2016.1.2
Here is what my data look like:
This is how the data look like when I transform them in FME 2015:
This is how I have bulkattributerenamer setup:
I have no idea what I am doing wrong as this seems to work ONLY in FME 2015. Any help is really welcome.
Thanks,
Radek
EDIT: I have attached a zip file with workspace and sample data.
Best answer by takashi
Hi @drakez, it should work theoretically, but as you observed, didn't work in FME 2016 indeed. Looks like the BulkAttributeRenamer (regex mode) in FME 2016 has an issue. As an interim workaround, try this setting instead.
Text to Find: .+
  • October 21, 2016
What does the result look like in FME 2016:
  • In the Inspector?
  • In the output dataset?
  • October 21, 2016
Here is the workspace mentioned: workspace.zip
  • October 21, 2016
  • In the Inspector?
I have uploaded a sample workspace.
  • October 21, 2016
Text to Find: .+
  • October 21, 2016
Text to Find: .+
Can confirm, weird behaviour.
Was also able to reproduce the problem with .* using FME 2017 build 17151.
  • October 21, 2016
Text to Find: .+
Seems that the issue is in using the regex itself. I have managed to fix it too by using this setting (denoting start of the string)
