Building a Diagram
  • Oct 12, 2020 7:37 PM UTC
  • 110 views
cipriancu
Forum|alt.badge.img+7
Hello
I try to build a diagram starting from a source-target table
the result should be something like this
Capture
is it posible to be made ? how?
deanhowell
Forum|alt.badge.img+24
  • Oct 12, 2020 10:04 PM UTC
Hello, how does your model know which way to turn i.e. left / right/ straight? If the points had some geographic location, then you could easily just create points and lines from each and then generate a polygon around the point with the ID.
cipriancu
  • Oct 13, 2020 6:32 AM UTC
I imagine this more like a grid mesh with few rules :
the starting point always will have ID =0 and will have the Y coordinate = 0
the nodes cannot have Y coordinate negative and the lines between nodes cannot intersect
it will look like a tree diagram rotated at 90 degrees since there is no loop
