BUG IN SQL CREATOR & SQL EXECUTOR
  • Aug 14, 2019 10:51 AM UTC
  • 91 views
Every time I need to run my transalation I have to open the SQL transformer make an edit (i.e. put in a space , delete it ) to get the transformer to run successfully. It is only the first transformer in the workspace that this occurs on the other sql transformers run as expected
This is the same whether I use SqlCreator or SqlExecutor.
Could it be the Sql statement I am using begins with Declare statement?
The error message is
Query failed, possibly due to a malformed statement.
however I don't change anything in the statement and then it runs successfully.
  • Aug 14, 2019 12:24 PM UTC
This is very strange. I use a lot of SQLExecutors / SQLCreators, and I've never had this issue.
Can you provide us with a minimal sample workspace that demonstrates the issue, as well as a complete log?
If that is not an option, you should consider contacting Safe support.
maiaeam
  • Aug 14, 2019 12:31 PM UTC
You tried to include the connection in "tool options - Database connections" before you created your SQL transformation, this must be because your desktop is not recognizing the database connection.
I copied the first few transformers to a new workspace to send . but cannot get it to error!
my original workspace is also now behaving. I guess it may have something to do with maiaeam's answer and the connection is now recognised somehow.
