Buffer question
  • November 20, 2015
  • 40 views
sigtill
Forum|alt.badge.img+25
Is it possible to create a negative buffer from an line (not area)? And is it possible to create a left-buffer from an area?
Best answer by takashi
If "a negative buffer from a line" means "a shortened line", the Extender (set a negative number to the Extension Length) or Snipper can be used to create that.
What's the "left-buffer"?
Edit: The Extender may not be good for a polyline, the Snipper would be better.
Takashi
  • November 20, 2015
Takashi
