Buffer Intersection
  • Mar 5, 2025 1:24 PM UTC
  • 144 views
katt
Forum|alt.badge.img+12
Hello, I would like to do the following (see attachment):
  1. Select these three lines (black, green, red) from a db table (how the table is structured I have to select the three of them and not only two)
  2. Create a 2m buffer around each line
  3. Identify the two lines (black, green), as they are the lines with a smaller angle to each other, and create a point where their buffers intersect /diverge (red dot)
  4. Create a perpendicular line to the green and black line starting from that point
  5. Create a point (yellow dots) 4m away from the intersection of the perpendicular line with black/green line on the black/green line
The first two steps are easy to do but I have troubles with steps 3-5. What transformers shall I use ?
max_h
Forum|alt.badge.img+39
  • Mar 5, 2025 2:54 PM UTC
Some suggestions you could try:
For step 3:
-custom ‘HorizontalAngleCalculator’ for each line then calculate the differences to get the smallest angles
-’Intersector’ (you can add a tolerance here, so no buffer needed beforehand), this transformer creates a node at the intersection
For step 4:
-’NeighborFinder’ (‘Insert Vertex On Base Feature:Yes’) with line and new vertex from step 3 as input
-VertexCreator for nearest base/candidate and ‘LineBuilder’
For step 5:
this could be tricky, but I would try to create a 4m long line and then rotate it with given angles
ctredinnick
Forum|alt.badge.img+22
  • Mar 6, 2025 4:46 AM UTC
Attached is a simple way, might be too simple, depending on how straight your lines are.
Offset the lines, then intersect them. If they’re straight and meet at the point, they will only intersect with each other at three points. The furthest of these three points will be on the angle where the two lines are closest. The NeighbourFinder attributes then tell you the coords/angle/distance of this vector which you can place your point along.
