BigQuery Reader SQL with regexp_contains fails before execution
  • Jul 7, 2021 4:23 PM UTC
  • 64 views
jbradfor
Forum|alt.badge.img+7
I have a SQL statement that contains a regexp_contains.  It works fine in BigQuery SQL Editor, but FME chokes on it before it even executes it in BiqQuery.  Even if I comment out the statement it still throws the same error unless I remove it completely.
regexp_contains(table1.col1, '^[[:digit:]]+$')
Do I have to escape this somehow?
Error :
Using Java Reader Interface Version 2.0 (Oct 31, 2000) with module GOOGLEBIGQUERY to read data
Google BigQuery: Using billing project xxx
java.lang.IllegalArgumentException: Illegal group reference
jbradfor
  • Jul 7, 2021 4:52 PM UTC
This attempt was via SQLExecuter > Format: Google BigQuery
I switched over to GoogleBigQueryConnector and the error went away.
