Big difference in behavior between TINGenerator in FME 2021 and 2025
  • Apr 1, 2025 8:27 AM UTC
  • 7 replies
  • 263 views
sleschi
I have a workspace in FME 2021.2.6 where I produce a TIN from a DEM with the TINGenerator. In this transformer there is a parameter called Tolerance. I was playing with this tolerance to find the right amount of detail, that is still acceptable for my task and reduces the amount of triangles in the TIN. Now we’re about to switch to FME 2025 soon, so I thought there might be a performance win with the new Version, so I gave it a try. But I found out, that this transformer does not work the same way anymore and whether I put in 1 or 100 or 10000 in the tolerance, it does not really matter. The result looks way different and in my opinion is worse, than with the 2021 version. Can someone explain me, how I can produce kind of the same results as with the 2021.2.6 Version? How can I reduce the number of produced triangles and level of details within the TINGenerator if the tolerance does not has any effect on this?
Thanks for your help
Simon
Different tolerances in the TINGenerator in FME 2021.2.6. The level of detail decreases with higher tolerances, as wished and expected.
Level of detail with tolerance 5 in FME 2025. Looks way different than above and has much more triangles than before with the 2021 Version.
nielsgerrits
Forum|alt.badge.img+67
Can you share your sample input? I tried to reproduce what you see by creating a workspace in 2021 and upgrade it to 2025 but I had no different results.
We are in the same boat, running 2021.2.6 and moving to 2025 this year when arcgis enterprise 11.5 is supported.
sleschi
  • Apr 1, 2025 1:53 PM UTC
Hello ​@nielsgerrits,
Thanks for your reply. I work with a subset of the original GeoTiff file. But the subset is still about 85MB in size. So I can’t upload it here. I provide a download link for the geotiff https://zueribox.stadt-zuerich.ch/zueribox/index.php/s/AhNcfBAcdiI8Pxd. I just set up a new blank workspace in FME 2025, read the geotiff, connected it with the TINGenerator, once with Tolerance 5 and once with Tolerance 100. It produced almost the same amount of triangles and more then 1000 times more then in FME 2021.2.6. I really don’t know what’s going on.
Cheers Simon
nielsgerrits
Ah, I tested differently. Yes I can reproduce what you see, but I’m not sure what to think of it. You probably want to submit a ticket for this one.
sleschi
  • Apr 1, 2025 2:36 PM UTC
​@nielsgerrits thank you for your testing. I think there just a big difference how this TINGenerator works in FME 2025 than it used to work in FME 2021 and I prefer the method used in FME 2021. But maybe I’m missing something here. I will submit a ticket and reference this post here. I hope I can get some hints about it.
Thanks again for your help
Simon
itsmatt
Forum|alt.badge.img+48
  • Apr 2, 2025 9:22 AM UTC
I know that safe were planning on reworking the 3D modelling stuff - possibly this has caused the changes.
If I look at your screenshots I can convince myself that some sort of tiling has been used ​@nielsgerrits  do you see something similar in your testing with different data?
My guess is that FME has added points along the tile boarders and has used these in the triangulation. It’s likely that these boarders are being treated differently when using the surface tolerance - possibly these boarders are treated as breaklines. I’ve seen this in previous algorithms. Have you tried settings the breakline tolerance to anything other than automatic? Try setting it to the save value as Surface Tolerance.
It’s hard to say if this is a bug or a feature. My guess would be a mixture of the two.
Note: The tiling approach is likely indented to reduce the amount of memory needed by processing the data in chunks. This should also allow for parts of the process to be performed in a multi-threaded approach as well.
nielsgerrits
Yes I think I see the tiles forming in my testdata. Must admit I don’t do a lot of work like this, but I can understand the issue Simon has with the different results. And tweaking the surface tolerance parameter does not seem to do very much either.
sleschi
  • Apr 4, 2025 9:50 AM UTC
Thank you guys for your answers and looking in to this. I submitted a request on this topic to Safe and already got a first answer back. Here is what Dave Campanas wrote:
“We did completely re-write the TIN generation code for FME 2024, which is resulting in the differences in the results you are seeing. However, I do agree that the Tolerance is not having the desired effect, so I have created a problem report for our development team (FMEENGINE-86426), requesting another look at the new code.”
So maybe there is an issue with the tolerance setting and they will look into this. Dave also mentioned as a workaround to use a MeshSimplifier after the TINGenerator to simplify the TIN more. I will try this and see what I get out of it. I will let you know, if there are any updates on this topic from Safe.
Simon
