Best method to reproject Large raster
  • Sep 17, 2019 5:01 AM UTC
  • 7 replies
  • 437 views
kieranmg
Forum|alt.badge.img+3
Hi All,
I have 15 ECW files with a total of 20GB~ and another one large area ECW of 44GB.
I also have the tif tiles for all of these images, about a total of 200GB and 600GB respectively
Goal:
Long term goal is mosaic 15 files on top of the 1 large file and reproject to use in GIS viewer.
Short term goal I would settle for having only the large image reprojected!(and let the App look after the rest on-the-fly)
I've only used the ECW files in my attempts so far to mosiac and reproject but the workspace slows dramatically it seems half way through. Then begins to show something like 'retry attempt 2' while processing
-ECW writer: Completed 50.83% of intermediate processing
Assuming at this point i'm running low on RAM. Using workbench 2019, 64bit, 32GB RAM and 1 TB of space
I've since doubled my memory to 64, without really any understanding as to what i need.
Hoping for some direction as to what resources i need to complete this job (without waiting weeks), or pointers as to a better method, i.e. using the TIFs instead, or somehow breaking the images up further.
Appreciate any advice given
featuremichael
Forum|alt.badge.img+9
i think this process can not be handled by your Computer.
Just 4 Info:
i used a 35MB ECW-File -> and a Reprojector and wrote a FFS-File.
35MB File -> 1,5 GB Ram usage and a FFS-File with 373MB (To Store the Data to Write as ECW-File)
I think u need a good server to perform this LARGE amount of Data.
  • Sep 17, 2019 7:52 AM UTC
Reprojecting rasters can be extremely time- and memory-consuming.
This very much depends on the type of transformation that's needed, but sometimes you can get away with using e.g. the Offsetter or the Affiner to rapidly get a suitable approximation.
Alternatively you will probably have to split up your rasters and reproject them in smaller chunks (Tiler) before merging them back together (RasterMosaicker) in the end.
gio
Forum|alt.badge.img+15
  • Sep 17, 2019 10:12 AM UTC
@kieranmg
As @david_r says.
I would tile the process and use a workspace caller to prevent to much memory hogging.
Workspace caller set to wait, give it space to clear memory.
For the mosaicking I would do this as well but after using extents (rasterextentcoercer) to set up groups.
So you could prevent mosaicking everything at once.
helmoet
Forum|alt.badge.img+8
  • Sep 19, 2019 7:08 AM UTC
Hi @kieranmg, I would opt for the suggestion of david_r, create a grid that clips your raster into smaller blocks and reproject the smaller blocks. After that you could try and mosaik them together. You might want to consider using a virtual raster format (VRT) in stead of one big raster file.
itay
Forum|alt.badge.img+19
  • Sep 19, 2019 9:05 AM UTC
Hi @kieranmg,
Is a large raster necessary? can you avoid reprojecting+ mosaicking ? If your goal is to display the raster(s) in a GIS viewer, you could consider servicing the tiles.
That way you only need to reproject the tiles, which is more efficient.
sigtill
Forum|alt.badge.img+25
  • Sep 19, 2019 11:57 AM UTC
Which software do you use to read the raster? You mention "GIS viewer" . Which Desktop software or Online viewer should show the data?
kieranmg
  • Sep 20, 2019 6:21 AM UTC
Thanks all, seems most feedback suggest tiling before reprojecting. I've failed this approach in the past as i had issues with black/white collars as ecw doesn't support nodata, adding the alpha band solves this but my s/w (PB spectrum spatial) doesn't support alpha band ecw yet. As suggested maybe another format is needed. Food for thought, thanks again for all your suggestions, theres 101 ways to skin a cat so it can be difficult for a newcomer to find the 'best' way.
Also, perhaps a point of reference for anyone thinking of doing something similar, i needed the following to reproject one large ecw of 44GB
w2016 server - 64GB-RAM - Disk space didn't seem to be a problem
FME Session Duration: 3 days 3 hours 17 minutes 45.4 seconds. (CPU: 354403.7s user, 168235.2s system)
END - ProcessID: 912, peak process memory usage: 59863728 kB, current process memory usage: 186432 kB
