Best FME practice to convert JSON (as HTTP _response_body) input for a table (Postgres)
  • Aug 24, 2023 1:56 PM UTC
  • 9 replies
  • 550 views
fbrws
BANNED
I need to convert:
"keys": [
<ordered list of field names>
"values": [
"<ordered list of field values, matching the keys field order>
What is the best way to do this in FME?
Input example: see attachment
Best answer by geomancer
Passing _response_body to a JSONFlattener does the trick for me.
geomancer
Forum|alt.badge.img+71
  • Aug 24, 2023 3:07 PM UTC
The ListKeyValuePairExtractor (from FME Hub) looks like a good choice here. You will have to expose the attributes afterwards.
fbrws
BANNED
  • BANNED
  • Aug 24, 2023 5:15 PM UTC
Hi Geomancer,
Thats a fast and complete answer! Thanks a lot. I will try it and report back.
Cheers
fbrws
BANNED
  • BANNED
  • Aug 25, 2023 8:42 AM UTC
The above example works like a charm. Thanks again!
But its getting a little more complicated. Instead of using a JSON file I am getting a JSON response from a RES API which I invoke with the HTTPCaller. After that I use a JSONValidator, JSONFormatter and JSONFragmenter to connect to the ListExploder, the rest is the same.
(The first part of this is from Exercise: Handling JSON - FME Web Services (imgscloudapps.com))
http_jsonConfiguration of the JSONFragmenter:
http_json3Configuration of the ListExploder
http_json4But I get an error with ListExploder:
http_json2What I am doing wrong?
fbrws
BANNED
  • BANNED
  • Aug 25, 2023 9:24 AM UTC
I get it working with the HTTPCaller in connection with TempPathnameCreator and the FeatureReader
http_json_featurereaderBut it feels cleaner (best practice, less steps) to use the response_body, although I haven't got it working yet.
What do you think?
geomancer
  • Aug 25, 2023 9:33 AM UTC
fbrws
BANNED
  • BANNED
  • Aug 25, 2023 9:48 AM UTC
Thanks again geomancer! It works perfectly. You are a genius :)
Forum|alt.badge.img+54
  • Aug 25, 2023 9:49 AM UTC
You are getting the error because the list you've exposed doesn't actually exist in the data if you have processed it using the JSONFragmenter setup pictured above.
Try a JSONFlattener instead, this should give you the lists you need.
Alternatively, you could save your http response to a file instead of an attribute, and then read that back in as JSON with a FeatureReader
geomancer
  • Aug 25, 2023 9:50 AM UTC
You're welcome, have a nice day! 🌞
fbrws
BANNED
  • BANNED
  • Aug 25, 2023 9:56 AM UTC
Thx eby! Really helpfull remarks. Your input is coming together below.
