backupConfiguration.fmw access to folder problem
  • Nov 19, 2018 4:24 PM UTC
  • 61 views
northswejohan
Participant
I have a problem with geting the backupConfiguration.fmw to work and have now looked into this problem alot. The error message I get is:
HTTPCaller(HTTPFactory): HTTP/FTP Transfer: Failed to create file 'C:\\ProgramData\\Safe Software\\FME Server\\resources\\backups\\' for resource download ''url''
The below feature caused the translation to be terminated
Storing feature(s) to FME feature store file `C:\\ProgramData\\Safe Software\\FME Server\\resources\\logs\\engine\\current\\jobs\\229000\\job_229856_log.ffs' (This logfile does not say anything more than the info above)
There seams to be a problem accessing resources\\backups, but the user have this access and fmesuperuser role .
If I use the url and token in a browser I get the backupfile.
Anyone knows about this?
Best/
Johan
Hi @northswejohan
Have you tried running the backup through the web ui, by going to the Back up & Restore option in the navigation panel?
If you try doing it to resources or download does it work?
You should be able to see the full backup log in the History panel.
If that doesn't work, would you mind sharing the full log?
