Backup is not working after upgrade to Server 2017.1
  • Nov 16, 2017 10:59 AM UTC
  • 76 views
clemensb
Forum|alt.badge.img+5
we upgraded our Server from 2016 to 2017.1
I created a Schedule to create a backup once a week, this job failes. When i open the job there is a notification "no log files exists" so i cannot check why this job failed.
So i tried to make a manual backup. It started the process but it never finishs. It doesn't matter if i choose Backup To Download or to a ressource. After i start the backup there is this notification:
If i want to check the logs in from Backup & Restore i get:
Are there any other logs where i can check whats the problem?
There are no other Problems and the Server works fine.
Thanks for your help!
  • Nov 16, 2017 11:10 AM UTC
First thing: Double-check the Server Username and Server Password parameters in the scheduled task.
If that's not it, you should check the FME Server system logs. Look under Resources/Logs in the GUI, in particular the following
  • service/current/rest.log
  • engine/current/fmeprocessmonitorengine.log
  • core/current/fmeserver.log
clemensb
  • Nov 16, 2017 3:23 PM UTC
Thank you. There was indeed a Typo in the Password (facepalm) would be great if there would be a notification or something, that tells you that.
But the manual Backup still feezes, but since the automated works its not so tragic.
boubcher
Forum|alt.badge.img+11
  • Jan 12, 2018 9:34 PM UTC
it's not working for me I did check the credential and all ok
attached is the Job log file
please any idea what may cause this
logfilebackup.txt
clemensb
  • Jan 15, 2018 7:26 AM UTC
It seems there is a Problem, @boubcher reminded me. First i thought there was a typo, because afterwards the backup succeeded, but now i get the error again. Most Times the automated Backup doesnt work. I got the same Error in the log and the credentials are ok.
