Autogenerated lines normal to a surface
  • Mar 13, 2020 1:50 PM UTC
  • 83 views
sigtill
Forum|alt.badge.img+25
I have approx 600 points based on top of a surface. I want to be able to generate a 5 meter long line in each of these which is in the normal direction of that surface.
This is to be used for planning boreholes in a tunnel.
Finding the normal of a surface is ok - but the normal of the point on a surface seems to be more difficult. The lines that needs to be generated is created manually on the last image.
Best answer by romanhassas
Hello @sigtill,
I have almost the same question, see the answers in the link.
https://knowledge.safe.com/questions/109614/drawing-perpendicular-line-between-3d-point-and-3d.html
romanhassas
  • Mar 16, 2020 8:47 AM UTC
Hello @sigtill,
sigtill
  • Mar 16, 2020 12:46 PM UTC
Hello @sigtill,
Thanks a lot - will look into it @romanhassas !
