autocad line length
franco69
Forum|alt.badge.img+11
Hi All,
i have a dwg with lines and want convert all lines which have a certain length into polylines....
how can I do that? which transformers to get the length an convert them into polylines?
Greetz
Franco
Hi Franco,
You can use the LengthCalculator to calculate the length of each input line.
If your goal is to insert vertices with a certain interval into a line segment, the Densifier might help you.
Takashi
- try to play with GeometryCoercer to make a polyline from line
- try to expose autocad format attribute (like autocad_entity or similar and manually change to a polyline one)
