Autocad DWG - only create layer if it contains features
  • August 21, 2013
  • 67 views
HI
I have a project that converts a large postgres database to Autocad DWG. When I pass in a bounding box parameter it extracts all the relevant features and translates them into a AutoCAD DWG file with multiple 70+ layers.
My problem is that every potential layer is produced in the DWG file whether they contain features or not. Is there a way of telling FME to only  create the DWG layers that contain features?
Thanks,
Mike
endest
  • August 23, 2013
You can set the DWG Writer Parameter - "Purge Unused Objects" to "yes".
mhab
Forum|alt.badge.img+10
  • August 23, 2013
Hello
I would need this option too !
Problem: I cannot find this setting in the DXF/DWG writer (FME 2012) anywhere ...
Is this a new option ?
