AttributeSplitter, Exposed Elements
  • Oct 19, 2015 2:16 PM UTC
  • 6 replies
  • 152 views
Hello,
I have a List created with the AttributeSplitter. When I right click on the list and choose 'Expose
Element' I can expose a however many number of list items as I want.
I've been connecting some of these items to attributes of
my destination datasource, and my conversion works. The items
contained in the list are written out to the proper attribute.  But
if I save my workspace, close it, then open it up again, all my
connected 'exposed elements' are gone, and I need to do it all over
again?
Can anyone let me know if there's a setting I can activate to hold onto all connected exposed elements?
Thanks everyone,
Regards Alex
Best answer by takashi
Which version of FME are you using? The issue may not occur in the latest version (2015.1.2.1 build 15539).
  • Oct 19, 2015 2:51 PM UTC
Hi Alex,
It's a known issue in FME 2015.
As a workaround, in the interim, you can insert an AttributeRenamer or AttributeCopier with the following quick operation, so that the mapping between list elements and writer attributes will be preserved.
Right-click on the link  (connection line) between the transformer and the writer feature type, and select the "Replace with > AttributeRenamer (or AttributeCopier)" command.
That's it :)
Takashi
  • Oct 19, 2015 2:59 PM UTC
  • Oct 20, 2015 4:34 PM UTC
Hi Takashi
We installed the new version (2015.1.2.1 build 15539) and it works with the exposed elements.
Thank you for your support.
Alex
I am having the same issue as Alex in FME Desktop 2018.1. My workbench contains about a dozen NeighborFinder transformers, but no matter what I do, only a handful of them actually save the attributes that I expose after I save and reopen the workbench. Is it possible that the same bug exists in 2018.1?
xiaomengatsafe
Forum|alt.badge.img+11
Hi @cheriesouthwick. The behavior you described does sound strange. We might need to see your workspace and understand exactly what to do to reproduce the weird behaviour. Would you be able to post a separate new question, and attach your workspace and some details on steps to follow and where in the workspace we'd see the suspicious behavior? That would be very helpful! Thank you!
@xiaomengatsafe Unfortunately I can't upload my workbench because it is too difficult to strip it of company confidential information, however I have posted a separate question here: https://knowledge.safe.com/questions/91381/exposed-elements-in-neighborfinder-are-forgottenar.html
