I use an AttributeSplitter in order to split an attribute like
TK25|UK50|DOK
The data is read from an database an comes as string. Some of the attribute i have to edit additionally, so for some of them i use an attribute creator to edit the attribute.
The attributecreator will code this attribute in utf-8 (as i use a pipe as seperator i assume) and it isn't split by the attributesplitter.
Can you help me?
Thanks
Isabell
