AttributeManager Arithmetic Editor - Testing floats for equality?
  • Sep 10, 2021 9:41 PM UTC
  • 76 views
miczat
Forum|alt.badge.img+4
How in FME would you check that two floats are "close", given testing floats for equality can be a challenge?
e.g. "-23.123" as listed in an XLS compared to "-23.12300005" stored in a point feature class?
In Python I use the math.isClose() or assertAlmostEqual()
Thanks
Best answer by debbiatsafe
math.isClose() uses this formula to evaluate whether two values are close or not:
abs(a-b) <= max( rel_tol * max(abs(a), abs(b)), abs_tol )
You can try implementing this formula within an AttributeManager using math operators and math functions. Using the default values for rel_tol and abs_tol, it would look something like this:
@Evaluate(@abs(@Value(fc)-@Value(xls)) <= @max(@exp(-09) * @max(@abs(@Value(fc)), @abs(@Value(xls))), 0.0))
A result of 1 would be true (close). 0 would indicate false (not close). I hope it helps!
debbiatsafe
Forum|alt.badge.img+24
  • Sep 10, 2021 11:40 PM UTC
miczat
  • Sep 13, 2021 7:17 PM UTC
Thanks Debbi!
