Attributecreator/renamer
  • Dec 5, 2025 8:02 AM UTC
  • 84 views
nath
Forum|alt.badge.img+7
Has anyone else noticed that when you use an attribute creator in your model, or renamer, or in your manager where you reuse an existing field, it works perfectly in your model but is not transferred when you write it to your shapefile? I always have to use a separate creator at the end This used to be no problem at all.
I am now using 2025.2, but I had already noticed this in version 1.
alexbiz
Forum|alt.badge.img+35
  • Dec 5, 2025 8:49 AM UTC
Hey Nath,
I’ve never seen this behaviour before. Could you maybe create a very simple workspace that reproduces the issue and share it? That would help understand what’s happening.
