Attribute Manager has wrong attibute types
  • Apr 6, 2023 5:11 PM UTC
  • 5 replies
  • 169 views
rtreecare
I am taking a feature reader (ESRI geodatabase) and putting a feature class through an attribute manager.
The feature reader shows the guid fields correctly as guid.
FeatureReader_Shows_Correct_TypeHowever, the attribute manager shows them guid fields as buffer.
AttributeManager_Shows_incorrect_TypeThis is happening for all guid field. I've tried "reset table" and import from dataset in the attribute manager. I've also tried recreating the attribute manager. How can I fix the attribute types to be accuate?
Best answer by markatsafe
@rtreecare​ Internally, FME doesn't have a GUID data type. It's mapped to fme_buffer. The data (GUID value) will be unchanged.
rtreecare
  • Apr 6, 2023 5:16 PM UTC
I also tried removing the attribute manager. The next transformer (change detector) shows the guid fields as varchar(200). So strange.
  • Apr 6, 2023 7:52 PM UTC
hkingsbury
Forum|alt.badge.img+73
  • Apr 10, 2023 8:25 PM UTC
Ultimately, FME doesn't care what type the field is. Generally*, the only time it matters is making sure the correct data type is set in the writer
*there are some edge cases!
rtreecare
  • Apr 10, 2023 9:34 PM UTC
Thanks. The writer is the ultimate issue and I'm trying to automate the attribute types from the reader. Everything I would try to import the attributes from the reader, guid would be of type string and the feature service writer would fail to update/insert. Seems like manual work is still the best option. ​
@rtreecare​ If you're using the FeatureReader, then you can get the schema feature. The schema feature will also have the source types. This will give you the guid type:
attribute{60}.fme_data_type fme_buffer
attribute{60}.name SourceGUID
attribute{60}.native_data_type guid
On the dynamic writer, you can choose to use the native types by setting the attribute fme_format_short_name as described here
