Attribute Filter
terezia86
In incomming data to AttributeFilter has the table about 80 cells, after filtering has table only about 50 cells. What happend that 30 cells dissapear?
danilo_fme
Forum|alt.badge.img+45
  • March 11, 2019
Hi @tereziastredna
Did you check the output port < Unfiltered> ?
Thanks,
Danilo
terezia86
  • March 12, 2019
danilo_fme wrote:
Hi @tereziastredna
Thanks,
Danilo
Hi Danilo,
thanks for answer. The output ports are all filtered as I wanted. There are no unfiltered outports. But the quantity of datas in filtered attributes is not the same. For example: in my data input I have 10 tables which all consists of 80 cells with datas, after filtering by name I become again 10 tables, but only with 50 data cells. I have did it already a few times, but it has never happened before...
nielsgerrits
Forum|alt.badge.img+55
What version of FME?
Do you mean features (rows) or attributes (columns)?
danilo_fme
  • March 12, 2019
terezia86 wrote:
Hi Danilo,
Hi @tereziastredna
Thanks your feedback. Could you send the print? Or the Workspace template ( .fmwt ) to check?
Thanks,
Danilo
terezia86
  • March 18, 2019
Hi Danilo,
It all done! I had to change the input dataset. Now I have it all as needed. Thanks for your help!
danilo_fme
  • March 18, 2019
terezia86 wrote:
Hi Danilo,
Excellent @tereziastredna
I'm happy to help you :)
