@Relate invocation error in Joiner
  • September 24, 2013
  • 0 replies
  • 23 views
In my workbench, i have one joiner in main work bench and 2 joiners in custom transformer. last 2 are executing successfully but when it comes for joiner in main, flow stops over there, means no output from joiner. In log, i found following msg:
"2013-09-24 14:54:37|   6.1|  0.0|ERROR |Relation `Joiner' in @Relate invocation is not defined
2013-09-24 14:54:37|   6.1|  0.0|ERROR |A fatal error has occurred. Check the logfile above for details
2013-09-24 14:54:37|   6.1|  0.0|ERROR |... Last line repeated 5 times ..."
Strange thing is same transformer is executing on another workbench. I tried with all possible tables/parameters/prefetch variation, but still same behaviour.
Please let me know the resolution.
Thanks.
Subrat
