assign count to unique attribute values
  • Jan 8, 2018 3:30 PM UTC
  • 7 replies
  • 144 views
Hi, I would like to assign a unique count as a new attribute, based on the value of an existing attribute. I cannot find a solution: Counter, UniqueValueLogger and StatisticsCaltulator seem not be suitable for this. It is a large database. How do I manage this? I am not interested in the number of Pete's, Daisy's.
Example:
Old attributeDesired attributePete1Pete1Jacob2Daisy3Daisy3Daisy3
Sieger
erik_jan
Forum|alt.badge.img+26
  • Jan 8, 2018 3:59 PM UTC
I would use the DuplicateFilter followed by a Counter.
Then a FeatureMerger to merge the desired attribute on the original rows merging on the old attribute.
If the data is in a database (Oracle in my example), you could use two SQLCreators:
1) Complete table
2) Select old attribute, rownum from table.
Then a FeatureMerger to merge the rownum as desired attribute on the complete table.
lau
Forum|alt.badge.img+3
  • Jan 8, 2018 4:01 PM UTC
You can use an AttributeCreate and enable adjacent feature attributes (see my workspace)example.fmw
  • Jan 8, 2018 4:12 PM UTC
Excellent. Also you can use the Default Value option, so that the conditional value setting could be simpler a little.
mark2atsafe
Forum|alt.badge.img+59
To throw out another idea, use an Aggregator-Counter-Deaggregator combination.
  • Jan 8, 2018 7:57 PM UTC
You can use a Matcher based on the Old Attribute and use the generated Match ID Output Attribute.
Note that you will have to deal with the features coming out of the NotMatched port and assign them a value by yourself.
  • Jan 9, 2018 7:57 AM UTC
There is more than one way. Assuming the records are sorted by the Old attribute, this workflow is also possible.
Thank you all! Glad that it works now...
