Ascii to Shapefile -
salgardi
Hi there,
I have an Ascii grid file.
The FME can read the file I have also added a Raster Cell Coercer transformer to create a shafile this simple workbench works fine.
Issue - How the raster values can be displayed in the shapefile. The shapefile has no attribute data (cell values).
I need to display the raster values in the shapefile. Any hints will be greatly appreciated.
Thank you very much,
Sebastian Algardi-Camus
Workbench
Raster image
geomancer
Forum|alt.badge.img+50
  • May 2, 2024
The value is in a List.
You can use a ListIndexer to extract the value.
salgardi
  • May 3, 2024
Thank you very much Geomancer.
For those interested here is the workbench with an added aggregator. I just wanted to merge the the attributes. Maybe this can also be achieved by using the Attribute manager but I did not know how.
ListIndexer
Aggregator
