Artifacts created with Dissolve > Aggregator
  • February 19, 2015
  • 62 views
Hi Everyone,
I'm finding that artifacts are being introduced in polygons created using a dissolver then aggregator.
Here's the boundary I can get with the ArcGIS dissolve tool:
However, using an FME dissolver > aggregator, basing the grouping on the same fields, I get artifacts introduced at the borders of the input polygons:
A closer look at the polygons during an edit session:
We're not sure how these are getting created as our polygons have gone through the ArcGIS topology tools, and do not have gaps.
Any guidance appreciated!
Thank you!!!
-mb
  • February 20, 2015
ArcGIS applies a tolerance automatically when performing geometric operations.
FME generally manipulates geometries with full precision of floating point number.
I guess that's why you found the difference.
To resolve the slight gaps, try using the Snapper (Group By: <the same grouping fields>, Snapping Type: Segment Snapping) before dissolving.
Takashi
  • February 20, 2015
Looking forward to the day FME gets a workspace-wide setting for precision/tolerance that is automatically applied for all geometric operations!
David
