Arithmatic in Tester transformer, syntax? wrong approach?
  • January 25, 2013
  • 67 views
Hello...
So I trying to run a multi criteria test on some data.
the first 2 criteria and simple column = xxxxxxxxx
The third criteria is a arithmatic query that I use in arcgis.
Here is what I though might work:
=((@Value(SWIFT_LOAD)-@Value(Permit_License_Date))<30)
I am returning no passing values and I know for a fact due to my arcgis map that there a a few hundred returns.
Any ideas? Shpould I not use the tester to peform this part?
I am very new to FME (a few weeks)
Thanks!
sigtill
Forum|alt.badge.img+25
  • January 25, 2013
Hi Garrett!
I tried to make the tester like this. For the complete workspace - copy this code and paste it in a NEW EMPTY workspace.
http://pastebin.com/ctmkMy2H
  • January 28, 2013
Awesome! Easy easy switch... works great =)
