AreaOnAreaOverlay not working as expected
  • December 13, 2012
  • 7 replies
  • 73 views
Hello,
I'm trying to calculate the amount of overlays of features in a geodatabase. Im using the AreaOnAreaOverlay transformer for this. However, what comes out of the transformer is quite strange. The amount of input features is 13, yet, the _overlays attribute gives values upto 24. Additionally, it fills in gaps (holes) that aren't part of the shape but are surrounded by the shape.
In the attached file I provided the workspace and files I'm working with.
ftp://ftp.safe.com/incoming/FME_AOA_error.zip
I would really appreciate the assistance, I don't quite understand how this is happening.
Best answer by boyen
I've contacted the help desk, apparently FME 2012 has a FILEGDB reader that does work while the GEODATABASE_FILE reader of 2011 doesn't.
  • December 13, 2012
Oh, I'm sorry. I'm using FME desktop 11 32bit on windows vista, if it makes any difference.
Forum|alt.badge.img+63
I'm having some trouble downloading your file, so it's hard to come up with an answer. If 2 features overlap, the AreaOnAreaOverlayer will cut them up into the overlapping parts and create an _overlaps attribute per part that notes how many parts exist on that particular spot.
Off the top of my head, the only way to get that kind of _overlaps numbers with only 13 input features is if they're either large aggregates or self intersecting ones. But again, I'd have to see your actual data to give a defiitive answer.
  • December 14, 2012
Hello RedGeographics,
Thanks for your reply; another attempt at uploading the data: https://sendit.wur.nl/Download.aspx?id=7266daf4-36d5-4bc2-bfc7-e768a6737545
  • December 14, 2012
It seems like the previous file already reached the limit on downloads.
https://sendit.wur.nl/Download.aspx?id=79d09597-91b4-4a5a-b225-f1c0d5cb54e1
  • December 14, 2012
  I saw your workspace. Probably, you should check "Group by" parameter of Aggregator. If you erase "_overlaps" in the parameter box, what will happen?
  • December 14, 2012
Hello Takeshi,
That doesn't quite fix it. Holes are still filled with overlaps. Even when the aggregator is entirely removed (or a visualizer is connected prior to the aggregator) the problem persists. Thanks for helping though!
  • December 19, 2012
