I'm trying to use the AreaGapAndOverlapCleaner to fill gaps in my polygons. This works fine without grouping, but as soon grouping is enabled, the donuts and other slivers in the polygons are not filled any more. See screenshots below. The tolerance in both situations is 25cm. The only changed setting is the grouping. I used the AreaGapAndOverlapCleaner for many years now and never experienced this before. In most situations I used ‘automatic’ as tolerance.
I'm using Form 2026.2. I also tried to recreate the process in 2025.2.4 and still experience the same issue.
Does anyone know why the donuts and slivers are not removed when grouping is enabled?
Grouping disabled: all small holes are filled (as expected)
Grouping enabled: small holes and slivers still present.
