Areabuilder is missing building some Areas
  • Sep 23, 2021 1:18 PM UTC
  • 80 views
mikamattila
When creating Areas from Lines using Areabuilder some areas are lost in the process. One example in the attached workspace, data and images is an area with "externid" "0381>NYNÄS>1:7>2". Not sure how many others are missing.
tomfriedl
Forum|alt.badge.img+14
  • Sep 23, 2021 3:11 PM UTC
First time you must build areas and control the result! Next time you can use the SpatialFilter.
It's not nessary to use the LineCombiner:
AreaBuilderThe result is better if use the TopologieBuilder between Snapper and AreaBuilder.
mikamattila
  • Sep 23, 2021 6:39 PM UTC
Thank you so much Tom!
danilo_fme
Forum|alt.badge.img+58
  • Sep 24, 2021 1:07 PM UTC
Nice @tomfriedl​
