Area Gap and overlap cleaner doesn't keep the inside polygon boundary
  • Aug 16, 2019 3:47 PM UTC
  • 12 replies
  • 157 views
Hello
I am trying to use Area Gap and Overlap cleaner to clean up data after dissolve transformer. but it is not keeping the boundary intact for polygon that are inside another polygon but part of different group.
see attached. how can I fix this? this should not be selecting inside but boundary of inner polygon. i attached pic of settings for Area Gap cleaner.
Thanks!
@nikkia do you have a small sample dataset and workspace that you can share with the group so we can try and reproduce the issue?
  • Aug 19, 2019 8:11 PM UTC
FMESampFME_ShareWorkspace.fmwtle.zip
  • Aug 19, 2019 8:13 PM UTC
Here are the files. I am trying to dissolve boundaries based on different fields.
Thanks
Nikki
fmelizard
Forum|alt.badge.img+22
  • Aug 20, 2019 5:43 AM UTC
Thanks
Nikki
Hi @nikkia The polygons get "lost" in Dissolver_POLICE, not the following AreaGapAndOverlapCleaner. Enable Feature Caching to see the results of each transformer.
  • Aug 20, 2019 7:48 PM UTC
Hello @danatsafe Thanks for you reply!
I want to dissolve polygons by different fields but I don't want to loose the topology.
if you can look at EMS layer object ID 46 and EMS name Front EMS has some part inside west EMS but it doesn't show the relationship correctly and selects the whole polygon ignoring the inner polygon. And it happens after area gap transformer before that they stay separate polygons.
i hope this clarifies what I am trying to achieve. check this snap shot below i don't want inner polygon to be party of the big one.
fmelizard
  • Aug 20, 2019 8:25 PM UTC
Hi @nikkia Maybe you should dissolve (group by) both POLICE and EMS?
  • Aug 21, 2019 5:07 PM UTC
I don't know how is that going to help. I am doing it separately. I need them as separate output. and both have different service areas.
Thanks
fmelizard
  • Aug 22, 2019 12:29 AM UTC
Thanks
@nikkia The boundaries disappear because the values for either POLICE or EMS are the same on either side. Dissolvers change topology. Maybe try switching the Dissolvers? Have you looked at the feature caches from each transformer?
  • Aug 22, 2019 2:28 PM UTC
Dissolving by both EMS and Police doesn't help. It gives me multiple records of each EMS even after aggregation and give me not continuous polygons like attached.FME_multiRecord.PNGFme_Crevur.PNGFme_Crevur2.PNG
These 3 polygons should be one continuous polygon because they are next to each other and should have only one record after dissolve and aggregation since it is served by same EMS.
Yes i have been looking at feature caches after every transformer and found that after area gap i loose the inner polygon relationship as you see in the attached images in comparison to topology output.
Thanks for your help!
fmelizard
  • Aug 22, 2019 6:04 PM UTC
Hi @nikkia Can you please file a case about this? I'll follow up from there. Thanks!
  • Aug 22, 2019 7:17 PM UTC
done.
Thanks for helping!
@nikkia Thanks for adding your sample data and workspace.
Are you able to use FME 2019.1?
When I recreate your workflow in FME 2019, I think I get the result you need. For FME 2019 we did a lot of work on the Dissolver: to improve both performance and the underlying algorithms. This also allows you to simplify the workspace and get a better result. Below are images from the attached workspace (FME 2019.1): dissolver.fmwt
Original Data
Dissolved by POLICE
Dissolved by EMC
