Are .GDC files for vertical transformations reversible?
  • November 28, 2018
  • 10 views
I have converted data from NAD83 (CSRS) 1997 to NAD83 (CSRS) 2010, along with this conversion, vertical handling is converting the z values to CGVD2013.
I am now trying to reverse the transformation. I am able to successfully reverse the horizontal values using the (Reversed) transformation option. I am wondering if there is a reversed option for vertical .gdc files? or is a new file altogether required?
I am having no luck finding information online for this.
daveatsafe
Forum|alt.badge.img+19
  • November 29, 2018
Hi @michoo,
The Vertical Handling option 'Orthometric height -> Geocentric or ellipsoidal height' is the reverse of 'Geocentric or ellipsoidal height -> Orthometric height'. You should choose the same grid file for each.
