ArcGIS has a tool called Central Feature, which extract the centre point from a cluster using a weighted value and case field. Anything similar in FME?
  • Feb 18, 2020 3:59 PM UTC
  • 33 views
ArcGIS has a tool called Central Feature, which extracts the centre point from a cluster using a weighted value and case field. Anything similar in FME?
Forum|alt.badge.img+54
  • Feb 18, 2020 4:19 PM UTC
There is nothing out the box. You could do something similar using a NeighbourFinder with Candidates only then a listsummer to sum the distance to all other points then a sorter and a sampler to keep the point with the shortest distance
