Appending multiple feature classes in one workbench file?
  • September 20, 2013
  • 56 views
All,
I have 8 years worth of polygon data that I'd like to append to 1 feature class in SDE. The source data is from shapefiles.
I've set this up in a single workbench, and pointed all the readers to the same writer. It looked like it would work until I ran it, then I noticed what had happened:
- for each reader, the writer had created a new feature class in the SDE with the name of the writer with a 0 appended to the name, 00 for the next one, 000 for the next one, etc. In the end I had 6 SDE feature classes with names ending in various 0's...
Example: SchoolBoundary_Archive0
SchoolBoundary_Archive00
SchoolBoundary_Archive000
SchoolBoundary_Archive0000 etc. etc.
Now I'm guessing this isn't the desired workflow, so I'm wondering what my best course of action would be in order to append this datasets together. Perhaps I should create a seperate workbench file for each?
Any thoughts appreciated.
Thanks!
Matthew Baker
Denver Public Schools
Best answer by takashi
Hi Matthew
The same feature class should have the same feature type name.
I don't think you need to create multiple writer feature types. You can send every features coming from multiple shape files to one writer feature type (SchoolBoundary_Archive) in a workspace.
Takashi
  • September 21, 2013
Hi Matthew
Takashi
fmelizard
Forum|alt.badge.img+22
  • September 23, 2013
See David's exellent answer here:
http://fmepedia.safe.com/AnswersQuestionDetail?id=906a0000000coksAAA
Hope this helps,
Itay
Takashi and Itay,
Thank you!
Takashi, your method was what I was after. Good to know I can point multiple readers at 1 writer! Great stuff!
-mb
