Append to SDE from joined Excel spreadsheets and address point feature class not working properly. It's only appending the attributes and not appending the geometry.
  • Aug 25, 2020 3:49 PM UTC
  • 81 views
cshir065
Hello,
I wrote a tool to join 3 Excel spreadsheets (solar data and 2 different meter tables) and an address point feature class. I tried appending this data to a SDE geodatabase feature class called, Distributed Generation. The writer only appended the attributes and not the geometry. I'm not sure why the geometry is getting lost during the translation. (As a temporary work around... i wrote it to a file geodatabase and am manually appending in ArcMap).
I have attached a screenshot of my workflow and parameters of the writer. Any help or ideas would be greatly appreciated 😊
SolarExportHelp2
SolarExportHelp1
Best answer by debbiatsafe
I would recommend double-checking the FeatureJoiner transformers, FeatureJoiner_3 in particular.
The address point feature class is connected to the Right input port. Is the Geometry Handling parameter set to 'Use Right' in FeatureJoiner_3?
debbiatsafe
Forum|alt.badge.img+24
  • Aug 25, 2020 11:07 PM UTC
cshir065
  • Aug 26, 2020 5:34 PM UTC
@debbiatsafe​  Thank you so much... that solved the problem. I had missed that detail in 'FeatureJoiner_3' 👍
