Any idea how to correct geometry to right location?
  • Nov 13, 2023 8:28 PM UTC
  • 155 views
pearly1
Forum|alt.badge.img+9
Here i have some Lines extracted from DWG and thought i set them to the correct projection. all seem right except for one file that is way off "Asbuilt - Sewer Existing" I noticed that the autocad_origion x,y are the correct extents but the geometry have different xy coordinates. any ideas on how to set this correctly would be appreciated. Many Thanks!
Best answer by featuremichael
@pearly1​ Good Morning,
Info:
"Ignore User Coordinate System (UCS)Instructs FME to ignore the user-defined coordinate system of the file being read. By default, FME applies the UCS when reading the coordinate data.
Usual AutoCAD-to-AutoCAD translation setting: Always selected"
you find this in your Autocad reader settings in the Navigator Window.
  • AutoCAD Reader:
    • Parameters
      • Advanced
        • Ignore User Coordinate System (UCS): Standard is Set to No
2.) Try to set the "Insunits" to 0 in autocad (console)
3.) Try to save the dwg to dwg2000 and try again
4.) clean the dwg file for error
featuremichael
  • Nov 14, 2023 7:08 AM UTC
Info:
  • AutoCAD Reader:
    • Parameters
      • Advanced
