Aggregator producing bad geometry
  • June 16, 2015
  • 255 views
I have a problem with the Aggregator transformer producing invalid geometry. A shapefile with 4 polygons is initially passing through a Geometry Validator (all tests) and are all passing. An Aggregator transformer is then used to merge them and an identical Geometry Validator after this is finding un-repairable self-intersections in the geometry and therefore failing my workspace. Has anybody had this issue before?
The Aggregator has default values set apart from grouping the 4 polygons by an attribute.
Best answer by takashi
Probably the polygons are overlapped each other. If you allow that, uncheck OGC issues of the GeometryValidator. Otherwise, you may have to fix the polygons not to overlap.
Takashi
  • June 16, 2015
Takashi
