Aggregator, not Merge Incoming Attributes
  • Aug 1, 2018 10:39 PM UTC
  • 136 views
hlouie
Forum|alt.badge.img+17
Table of attributes I want to merge with Group By: FILENAME
Input
Aggregator
Output
Desire
  • Aug 1, 2018 10:46 PM UTC
The output is correct, since <null> is a value. Consider using the NullAttributeMapper to remove all <null> values (i.e. change to <missing>) to get the desired result.
hlouie
  • Aug 1, 2018 10:58 PM UTC
Success, the fields need's to be "MISSING", NULL and BLANK don't work.
Thank-you
  • Aug 1, 2018 11:15 PM UTC
Good to hear.
<empty> is a string value consisting of no characters; <null> is a special value indicating that the attribute exists but it doesn't have a valid value; <missing> indicates that the attribute does not exist.
