After a recent windows update my FME refuses to bootup
  • Jun 19, 2020 12:20 PM UTC
  • 7 replies
  • 147 views
Just updated windows 10 and can no longer boot up FME 2019.2.0.
Any ideas how to fix?
  • Jun 19, 2020 12:23 PM UTC
Any errors or messages? Either on screen or in the Windows event log?
The most obvious thing to try is to re-install FME, version 2019.2.0 is available here: https://www.safe.com/support/downloads/#past-versions
  • Jun 19, 2020 12:24 PM UTC
No, the splash screen pops up, then disappears
And in the Windows event log?
  • Jun 19, 2020 12:25 PM UTC
Have already repaired, uninstalled and re-installed.
Just checked my logs:
Windows log event:
Faulting application name: fmeworkbench.exe, version: 2019.7.38.19801, time stamp: 0x5dc2486a
Faulting module name: Qt5WebEngineCore_fme.dll, version: 5.12.3.0, time stamp: 0x5d00105f
Exception code: 0x80000003
Fault offset: 0x0000000000b9f67f
Faulting process id: 0x10b4
Faulting application start time: 0x01d6463471478fc9
Faulting application path: C:\\Program Files\\FME\\fmeworkbench.exe
Faulting module path: C:\\Program Files\\FME\\Qt5WebEngineCore_fme.dll
Report Id: 050d3c90-6c15-44e8-9ed4-25519022f007
Faulting package full name:
Faulting package-relative application ID:
  • Jun 19, 2020 12:27 PM UTC
You can have a look here https://knowledge.safe.com/articles/894/troubleshooting-an-fmeexe-crash.html
If nothing works, consider contacting your FME reseller, or Safe support.
Forum|alt.badge.img+54
  • Jun 19, 2020 12:51 PM UTC
I had the same a while back on my home laptop, but I just installed 2020 instead :-)
  • Jun 22, 2020 10:11 PM UTC
Hi Alex, I am also experiencing the same problem, did re-installing the application fix your problem?
