Affin or offset polygons to the pixel coordinates of the corresponding aerial image
  • Jun 21, 2023 11:19 AM UTC
  • 120 views
a_afiaax
Hello FME community,
I am currently working on a deep learning project that involves preparing training samples for building polygons.
I have the building polygons in an OGC GeoPackage file with Coord.System EPSG: 26916, as shown in following screenshot:
image_001
Additionally, I have the PNG aerial images for the same area without projection, which means every aerial image X,Y starts from the upper left (0,-0) and ends at the lower right (2000,-2000) as shown in following screenshot:
image_002
I need to have the polygons of the training sample in pixel coordinates for each corresponding image. The output should be a CSV file that includes the vertices of every polygon in pixel coordinates as shown in following screenshot:
image_003
I have attached the datasets for better understanding.
Does anyone have any ideas or potential solutions?
Best answer by daveatsafe
Hello Daveatsafe,
Thank you for your helpful solution and the attached FME-workbench.
However, I encountered an issue where the offset-transformer moved all polygons to (0,0) of the projection of all images not to the (0,-0) of every non-projected PNG image, and they are overlapping each other , as shown in this screenshot:
image_00
Each image is 2000 pixels * -2000 pixels, and each polygon corresponds to a specific house on an image, as shown in this screenshot:
image_01
Before extracting the pixel coordinates of every polygon, I need to offset the projected polygons of every image to the right place in the their associated non-projected PNG image (2000 pix * -2000 pix and 0,-0 origin for every PNG), as shown in second screenshot.
Do you have any suggestions on how to achieve this?
I have attached the Waukesha projected TIFF images i used, corresponding PNG images for deeplearing and the FME-workbench for better understanding.
Having the GeoTIFFS is a great help, since they contain the georeferencing needed to align to the polygons. I am attaching a workspace that will extract the origin and pixel size from the GeoTIFFs, then use this info to move and scale the polygons to align to the pixel space coordinate.
daveatsafe
Forum|alt.badge.img+24
  • Jun 26, 2023 9:08 PM UTC
Hi @a_afiaax​,
The key step would be to determine the georeferencing of the images.
Based on the image names, they are part of an orthophoto tile set, but unlike most tiling schemes there appears to be some overlap between images 1_34_21 (south) and 1_34_20 (north). Being PNG files, they would have no internal georeferencing, and would need sidecar PGW or WLD files. Without this georeferencing, there is no way to tie the building outlines to the imagery.
I took a look at the Waukesha County GIS Portal, and found that their interactive orthophoto download only offered PNGs without any georeferencing, which isn't that helpful. However, they did offer MrSID tiles through their Elevation and Imagery download page (https://gis2.waukcogeo.com/portal/apps/webappviewer/index.html?id=32f4e52f72d642deb67d0f330db1ab1b). MrSID files are FME-readable, and are properly georeferenced.
I am attaching a workspace to extract both PNG coverage of each building from the MrSID file and the Excel WKT for the polygons within that image. Some of the buildings lie partially outside the ortho extents, and may give incorrect images. The WKT coordinates will be from the image lower left.
a_afiaax
  • Jun 28, 2023 3:05 PM UTC
Hello Daveatsafe,
image_00
image_01
daveatsafe
  • Jun 28, 2023 4:12 PM UTC
Hello Daveatsafe,
image_00
image_01
a_afiaax
  • Jul 3, 2023 9:28 AM UTC
Hi @daveatsafe​, I wanted to express my gratitude for your helpful solution and the attached FME-workbench. It worked well.
