Advanced browser query
  • November 4, 2013
  • 28 views
I have a directory which contains multiple file types.  I only want to read the .shp and .tab files and am trying to define this in the Advanced Browser.  I know if I just want .shp files I can put something like:
C:\\Folder\\Folder\\**\\*.SHP
However, is there a way to define it for both .shp and .tab in the one go?
Thanks,
  • November 4, 2013
This setting maybe works: C:\\Folder\\Folder\\**\\*.{shp,tab}   Here is description about search patterns of Path Filter.  Directory and File Pathnames Reader Parameters http://docs.safe.com/fme/html/FME_ReadersWriters/Default.htm#path/PATH_reader.htm
Takashi
  • November 4, 2013
Hi Takashi,
Thanks that works with the Generic Reader!
I did notice that when I use the {shp,tab} method with the Generic Reader, my outputs are shape_polygonz.
Whereas, when I use two separate MapInfo and ESRI readers, my outputs are shape_polygon (without the z).
Do you know why this would be the case?
Thanks!
