Adding writers tot bookmarks
  • Apr 4, 2018 9:58 AM UTC
  • 6 replies
  • 79 views
nath
Forum|alt.badge.img+7
it may be a stupid question, but if you add a writer/reader/inspector in fme2018 to a transformer that is in a bookmark, he always puts it out of the bookmark. My model is very large and has a lot of bookmarks that run into each other so that is not so convenient. Is there a way around it?
Thx
Nathalie
Best answer by andreaatsafe
Thanks @nath for reporting this! Our team is aware of the issue and is working to resolve it (PR#82979). I'll update here when the fix is available.
  • Apr 4, 2018 10:09 AM UTC
Definitely not a stupid question because I was able to reproduce the same thing(?) by adding just about any transformer while inside a bookmark
Not very smooth...
  • Apr 4, 2018 11:15 AM UTC
Not very smooth...
Interestingly, the symptom disappeared after unchecking the "Draw Bookmarks with a filled background" option (FME 2018.0.0.1).
  • Apr 4, 2018 11:18 AM UTC
Good observation. I suspect Safe needs to work on their collision detection algorithm ;-)
bertmeskens
Hi Nathalie,
I don't think there is much you can do about it. My advice would be to space out your bookmarks, so you have room to add new transformers and readers/writers. I usually leave an area the size of 2-3 transformers around a bookmark, and use junctions to streamline it all and avoid long lines. A handy tip: if a transformer is only a bit within a bookmark and you double click the edge of the bookmark, it adjust to include the transformer.
Bert
andreaatsafe
Forum|alt.badge.img+17
  • Apr 4, 2018 4:34 PM UTC
andreaatsafe
Hi @nath,
I'm please to let you know the problem reported with adding readers/writers/transformers to a bookmark has been resolved! The fix is available in the latest FME 2018.1 beta (build 18449 or higher) release found here.
