Adding data to road measures
  • Mar 26, 2018 9:15 AM UTC
  • 9 replies
  • 81 views
Dear FME community,
I have a road dataset with lines that looks like this:VNKNNKVSTBSTLEN102010402005001000102010406008001000
The columns VNK/NNK are just identifiers for the road segment, the columns VST/BST are the measures (in metres) and the in column LEN is the value for the absolute length of one road.
The above table means, that one road segment 1020-1040 is divided into the segment from 200m - 500m (with a value for XYZ), and then from 600m -800m (with a different value for XYZ). The complete road goes from 0-1000 metres.
Problem: I need to fill the "invervalls" with Zero-Values. If the road has the length 1000 metres, then there are no values from 0-200, from 500-600 and from 800-1000. I can calculate the missing values from start (0-200) and the end (800-1000), but how do I get the interim value (500-600)? The could be many intervalls :-)
Goal: The target table should look like this (the bold lines were added):VNKNNKVSTBSTLEN10201040020010001020104020050010001020104050060010001020104060080010001020104080010001000
I already put these road segments into a list and calculated the ranges, but I would like to add the missing lines, not just the beginning/end. Any hints how this can be achieved?
Kind regards
Thomas
lars_de_vries
Forum|alt.badge.img+10
You could use a Sorter and an AttributeManager transformer. When you sort the features first by segment and values, you can use the option of looking at 'Adjacent Features' to see whether VST from the next feature matches the BST value from the current feature. You can use feature[+1].VST to check or set the value from the next (or [-1] for the previous) feature.
  • Mar 31, 2018 3:13 PM UTC
A geometric solution. Create a line from (0, 0) to (LEN, 0), generate measure on it, split it by the given measures, then extract measures of start and end nodes for each segment.
  • Apr 20, 2018 12:36 PM UTC
Thank you very much @takashi for your solution with the screenshot (and sorry for my late response, I didn't see that another answer was posted in the meantime). Your way works like a charm!
  • Apr 20, 2018 12:41 PM UTC
Thank you @lars_de_vries
I didn't know the function with the "Adjacent Features" before and will have a look of how it works.
  • Apr 21, 2018 11:29 AM UTC
There is more than one way.
I think the InlineQuerier could also be used effectively here.
select x.VNK, x.NNK, x.M as VST, y.M as BST, x.LEN
from Measure as x inner join Measure as y
on y.VNK = x.VNK and y.NNK = x.NNK and y.count - 1 = x.count
Interestingly, JSON too does it.
Root Template Expression
    let $values := fn:distinct-values(
        for $m in (0, fme:process-features("SUB"), fme:get-attribute("LEN"))
        let $v := xs:double($m)
        order by $v ascending
        return $v
    for $i in (1 to fn:count($values) - 1)
    return { "VST" : $values[$i], "BST" : $values[$i + 1] }
Sub Template Expression
fme:get-attribute("VST"),fme:get-attribute("BST")
  • May 8, 2018 7:31 AM UTC
Hi there, many thanks to @takashi and all the others!
I have an addendum to the above question:
The resulting table will look like this:
VNKNNKVSTBSTVALUE1231230200A123123200400A1231238001000B12312310001200B
Is there a way to "compress" it, like this? All values with adjacend VST/BST on the same road segment (VNK/NNK) should be combinded:
VNKNNKVSTBSTVALUE1231230400A1231238001200B
  • May 8, 2018 8:35 AM UTC
Can the value of "VALUE" be used to aggregate segments?
  • May 8, 2018 11:33 AM UTC
@takashi
I think so, but the problem is that I only want to aggregate where BST=VST, i.e. where there are no "gaps". If for example I have following table
VNK
NNKVSTBSTVALUE1231230200A123123200500A123123600800A1231238001000AThen the result should be:
VNKNNKVSTBSTVALUE1231230500A1231236001000A
When there is a gap (here: between station 500 and 600), it should be 2 or more seperate rows.
  • May 8, 2018 2:30 PM UTC
OK. A possible way is:
AttributeCreator Conditional Value Setting:
AttributeManager Parameters:
