Add zero in front of some numbers
  • October 30, 2013
  • 596 views
Hello
I have an attribute containting numbers from 1-99 and I would like to add zero in front of the numbers 1-9.
example:
1 -> 01
2 -> 02
3 -> 03
etc.
Is there an easy way to do this in FME?
Regards,
Stig
fmelizard
Forum|alt.badge.img+22
There are several way to do that, the easiest will be to add a prefix with the StringPadder, also the StringPairReplacer or the StringReplacer can do the job.
Itay
  • October 30, 2013
Hi Stig,
Yes, there are several ways. The StringFormatter could be also a quick way.
Takashi
I used StringFormatter and in Format String Attribute I put 02d.
In my test case that worked well. I hope that is correct.
Best regards,
Stefan
  • October 30, 2013
It seems that Stringpadder with prefix 0 and lenght 2 is working perfectly.
Thanks a lot for all the answers!
Stig
