Add existing file to output ZIP
  • February 27, 2015
  • 95 views
Hello,
I have a workbench which converts Oracle spatial data to shapefile. I am creating a zip file in output folder. Now, I would like to add a metadata file which is in same folder where output zip is created. Is it possible to add/move existing file from folder to output zip.
Cheers
John
Best answer by takashi
Hi John,
I would use Python again.
# Shutdown Python Script Example
import os, zipfile
if FME_Status == 1:
    zipPath = FME_MacroValues['DestDataset_SHAPE']
    metaPath = <existing metadata file path>
    if zipfile.is_zipfile(zipPath) and os.path.exists(metaPath):
        # Add the metadata file to the zip archive.
        zip = zipfile.ZipFile(zipPath, 'a')
        zip.write(metaPath, os.path.split(metaPath)[1])
        zip.close()
        # If you need to remove the original metadata file:
        os.remove(metaPath)
Takashi
  • February 27, 2015
Hi John,
import os, zipfile
if FME_Status == 1:
        zip.close()
        os.remove(metaPath)
Takashi
  • February 27, 2015
Thanks Takshi. Worked like charm :)
fmelizard
Forum|alt.badge.img+22
  • February 28, 2015
A different approach using FME transformers is described here:
http://fmepedia.safe.com/articles/How_To/Including-Additional-Supporting-Files-in-your-Output-ZIP-File-Desktop-Zipster
