Add attribute to parcels from irregular area overlay
  • April 12, 2013
  • 59 views
I have a layer that is of scenic hillsides and I need to add an attribute indicating that to the parcels that are touched by the area.  When I used the AreaonAreaOverlayer, it clipped the parcels to match the scenic hillside area.  I need a way to add an attribute to the required parcels without changing their shape.
  • April 13, 2013
Hi Joan,
How about using SpatialRelator or SpatialFilter?
Takashi
Thanks I will try that out and see how it goes.
